hi I'm new to this fourm stuff, i got a ke 17 and want to convert the motor to a 4age or 4agze at the moment i have a 4age motor and t50 gear box out of a ae 86, what is the best diff to get? and tail sharft? and does anyone make or sell engine mounts and what other mods are required to do this conversion?
thanks guys
james.
extractors, exhaust, spedo drive, clutch line, mounts (engine and g box), custom drag link, fuel system (inc larger supply line, return line, surge tank, newer fuel pump).
probably would go a t series diff, tailshaft must be made. i was doing this in my 10. if you search the tech there is a 4a into ke1x. or rc rides i can't remember which one it is.
thanks guys
james.
hi james i went down this track a few years ago motor hit the firewall exaust too tight onthe subframe no room on the brake mastercyl etc etc sold the lot and put in a 7k goes almost as good and bolts straight in with a minor sump mod hope this is of some help cheers lou
