Ocean Spec Ta22
fix: buy a good ta22 shell and change over all the good bits
except the rust part. look at it, the rails are f@$ked, the floor is f@$ked, it has NO strength, it's going to tear in half!
and osix just doesn't understand that, he's more worried about a 2 pak paintjob and getting some indicators shipped over from australia
or using that orange te21 with the fibreglass guards, it's even closer to him!
TA22s aren't rare over here. you'd pick up a overrated one for like $1500, you could pick up a registerable shitter for a few hundred. they're like, one step above old corollas
THE CHASSIS IS RUSTING BADLY DOOR MIGHT FALL OFF DUE TO RUST
That says it all :)
And how do you bolt the flares onto it then nick?? The nails wont hold man :)
er, have any of you read the actual thread lately?
have you seen the repair work he's had done? the entire floor and sills have been rebuilt out of 1.6mm sheet, and it is tidy work. he's floored just about everyone on toymods with his persistance and this call WILL be saved, and probably become very tidy in quite a short amount of time
we're whingeing about carbs and windscreen plenums, this guy has to rebuild from the floor up. we go to the local wreckers, osix is travelling between COUNTRIES to find parts. give him some credit
here's some of his pics if you're too lazy to mosey on over to toyfags
Fair enough, but it's just a celica.
As you said very first reply Jamie, buy a new shell and swap it all over
he lives in bumf@$k nowhere. there ARE no other shells
he could always import one, but it's alot of bother and he IS in the philipines, the panelbeater is probably working for 5 bucks an hour so why not fix it? :)
