4K-C Electronic Ignition
Hi
I've just started to get into the old corollas, ive got a ke70 with a 4k-c in it and it has points in the dizzy and i was wondering if anyone would know where i could get an electronic ignition kit for one as I'm sick of fiddling around with point.
thanks
luke
Keep in mind the advance on these seems to be a bit of a compromise. Keep an eye on this thread:
Linky
Edited by snot35
Yes I found that a very interesting read. Lucky I haven't purchased one yet sounds like they're not worth the hassle.
Well, I wouldn't say that...
Its just that while you will get a cleaner spark and better running, its a bit more than just plug and play.
When i find a "named" spring that fits it then I can say... "go buy a 'something' and pull the spring out of it" :laff:
See if you can still buy one of these. Your points will last forever and only need the gap checked every once in a while.
I would still recommend finding a distributor that's been changed to inductive or hall effect as they output a better signal. The kit can be configured to which ever you have.
Another option:
Linky
If you don't mind ebay and getting your hands dirty. Something based around the Bosch BIM024 module will actually make a really strong ignition. These setups are very powerful.
thanks for link
I'm currently in the middle of building a 4k-c for the first time so i might buy one of those distributors
thanks for all the help and info
luke
