ke70_1982 Posted April 9, 2011 Report Posted April 9, 2011 hey every on i just got my ke70 up and running and i am looking to do the 4A-GE conversion. just wondering if i could get a parts list of everything i need to go from a 4k engine to a 20 valve 4age engine i want a parts list of EVERYTHING down to what nuts and bolts i need. please and one more thing i was wanting to find out about the ae86 body kits onto a ke70 what needs to me modified to make it fit on a ke :) tannks regards Ben Quote
ninja-philbo Posted April 10, 2011 Report Posted April 10, 2011 yes they fit with mods have one I'm my gurage was on my ae71 pano and on slw45s ke70 dude search theres plently of info and a 20v isnt a bolt in conversion if u don't have around 3grand just got the motor conversion not including box tailshaft pedalbox k frame then id be selling ur ke70 buying an ae71 ans putting a 4age 16v smallport in alot cheaper and just as fun Quote
Sam_Q Posted April 10, 2011 Report Posted April 10, 2011 (edited) hey every on i just got my ke70 up and running and i am looking to do the 4A-GE conversion. just wondering if i could get a parts list of everything i need to go from a 4k engine to a 20 valve 4age engine i want a parts list of EVERYTHING down to what nuts and bolts i need. please and one more thing i was wanting to find out about the ae86 body kits onto a ke70 what needs to me modified to make it fit on a ke :) tannks regards Ben Ben: do a search for ke70 4age conversion and they will talk about the basic parts like pedal box and the like, as for the 20v bits here is what I advise: trumpets and filters or custom rear bypass plate side water outlet block off plate New top water outlet External thermostat T50 gearbox spacer plate- if you run a heater 20V dizzy cover rwd clutch line coilpack adapter plate 1NZ coils Spigot bearing Visit my website for information about the conversion. s-86.com Edited April 10, 2011 by Sam_Q Quote
ke70dave Posted April 10, 2011 Report Posted April 10, 2011 "T50 gearbox spacer plate- if you run a heater" whats this for? ----- ive started filling in the "how to put a 4age into your ke70" in the FAQ, its in its early stages...my html skills are somewhat limited! but 4age into ke70 has got to be the most documented conversion on the internet! Quote
Sam_Q Posted April 10, 2011 Report Posted April 10, 2011 tilts the gearbox up to make a little extra room at the back of the engine. http://s-86.com/s-parts-t50-spacer.html Quote
ke70dave Posted April 10, 2011 Report Posted April 10, 2011 ah yeah i see now. I've seen that before on your site. Good idea. Though i guess it makes the uni joint work a little bit harder. I had visions of spacer plate between the gearbox and the engine...not sure why. Quote
Sam_Q Posted April 10, 2011 Report Posted April 10, 2011 2 degree angle change- I measured it, so it's very gentle. Quote
