Helpp Pleaseee!!!
hey guys
my babys hurt :( I'm guna jack her up tomorrow so i can have a look but thouhgt id post this to get some rough ideas and sugesstions
its a ke30 - 4k -4speed
the problem is firstly its very hard to put in to gear, when i get it in gear it makes a clunking noise, when you take your foot off the clutch while its in gear it will not move cotinues to idle and make the clunking noise.
but none the less it goes into gear so i don't think its the box I'm leaneing towars clutch or broken stub axle?
please any sugestions tips or advice
would greatly appreciate it
thanks guys
mmmm, i say gearbox....
^ :y: Does it slip into gear without the cluth? Does this happen in all gears?
it happens in all gears, i havent tryed to put it in gear without clutch, i tryed to start it in gear and it started as if it was in nuteral plus the clunking noise.
thanks guys
might have broken the centre out of the clutch plate
Does the tailshaft turn???? Could be the diff.
thanks for all your help guys put it up on stands today and found the clutch plate in more peicess than it should be :)
thanks again cheers
thanks again cheers
well there you go, easy fix.
happened to a mates skyline after a big weekend.
made the same sounds as you said.
