Removing Front K - Frame
what is the best way to remove the front k-frame with engine and tranny still attached?
and do I have to undo the steering.
(i got a gregory's service and repair manual but it isn't helpful)
Remove engine and transmission together, remove crossmember, re-attach crossmember...
Or
Remove car off cross member
If the steering is attached to the crossmember, then yes.
Is there some reason behind this?
Edited by styler
i would like to transfer basically everything mechanical from one bent corolla to a straight corolla.
You'll have to remove the lower control arms from the x-member and the drag link from between the steering box and the idler arm.
Here's how I would do it I think
Pop the engine out
I would remove the struts.
Undo steering box and idler arm from subframe, Option could be to disconnect ball joints here as well
Undo steering coupleing,
Undo K frame bolts from subframe
Remove subframe
There a proberly at least 6 ways of going about it, Depending on what every thing is like.
Andy
