Fitment
will 15x8+0 offset fit under the guards of a ke30?
No way will they fit under the front guards. MAYBE just fit them under the rear but I doubt it...
15x8 0 will fit under the rear.. definately not the fronts though... 15x 8 should fit under the front but... will need +ve or -ve offset i'm an unsure.. as i don't have stock struts in my car to compare.
Edited by greenmac80
You could tuck the fronts with camber tops and run stretch, you'd get them under the front with 1.5 - 2deg and 195/50~
