Mini Spools
as the title states mini spools! Where can i get on in adelaide for my corona diff? Not sure on what series diff it is. But where?
What model corona ?
check the axle code on the build plate, if it is a F series and IRS you might be in some luck with diff options.
If it is F series and all else fails I have one here you can weld up lol
its an rt142 with a solid axle.. Non irs model!
Borg warner and i believe there is nothing off the shelf for them, weld it up.
