May 8, 201115 yr comment_522642 I picked up what i thought was rt104 wagon the other night,had a quick look under yep t series .Things soon changed in the light of day checked trans code nothing stamped (Why did they do this). So i pulled the diff out still thinking its a t series,as it had 10 bolts on the front of it never thought any problem. I pulled it apart this morning and tryed it in my ra40 housing and there is no way it will fit :bash: . As it turns out the car is a rt118 76 model which i was lead to believe came with a BW or tseries??but there is a third option. Any one no what would be in it?? Did rt104s come with t series diffs?? Any way i did get some front calipers ,driving lights, another tin of bolts :lolcry: thanks in advance rob Report
May 8, 201115 yr comment_522661 Yes some RT104 are T series, some Borg Warner so you will have to check first! All are leaf spring type as far as I know which is good. Check the ratio as well, may be quite low eg 3.9 Edited May 8, 201115 yr by styler Report
May 8, 201115 yr Author comment_522684 yeah the ratio is 4.3 and yes it was leaf springs. The axles wouldnt fit in to a tseries centre (alot bigger). So where some of the borg warner diffs bolted in from the front like early holdens HT type?? Maybe its a r or s series I'm baffled ,certianly not a bw with the bolt on rear cover The drive shaft yoke matches up to a t series. Report
