Tacho Troubles
Hey guys just got a ke70 stock 4kc so I put a after market tacho in but the revs seem to wonder a bit and seem to jump up under acceleration but not with the engine if that makes sence? Like have it in top gear put foot down and revs jump about 400-500 rpm when the car hasn't gained any speed oh also it's manual
Thanks miller
How much was the tacho?
Put a diode in with the circuit and it should filter that out a bit.
The tacho was $150 it's a 3 1/2 inch one I will try open the points up what should they be set to?
Ok opened the points up to .018
Still the same :$ seems to maybe creep up aswell like the other night was sitting on 4000rpm at 100k (4 speed box in place of 5 speed ) now today it's up around 5000rpm at same speed!!!
Points were a bit stuffed looking could this be it?
I'd go for the diode seen this problem a few times and diode fix's
Were abouts do I get a diode guys
