June 17, 201115 yr comment_532714 my dip dosent work on my ke70 why? where does the plug on the gearbox(reverse lights) plug into? and when i turn my lights on my back lights don't light up but my break lights work when i aply breaks and i think they are called park lights?the 1s on the side of my frount lights and below my back lights don't work? Report
June 17, 201115 yr comment_532715 woah woah woah!!! so many questions!! check the following in the following order: bulbs fuses grounds how did this all begin, all of a sudden they all stopped working? Report
June 17, 201115 yr Author comment_532717 no i brought the car off a mate he striped it tnside and out and i had to put it back together where will the earths be that i have to check all fuses are sweet and bulbs probley dodgey wiring ? Report
June 17, 201115 yr comment_532718 there is an earth near the rear tail light (inside the car), there is also one front right hand side of the engine bay. both have given me dramas before (when I've forgotten to put them back) by earth i mean a ring connector on some wires, which you put under a bolt. Report
June 17, 201115 yr comment_532733 Got a multimeter?? $10 from Jaycar... That will tell you if you have 12V coming to the bulbs or not. Report
