ninja-philbo Posted June 22, 2011 Report Share Posted June 22, 2011 so basicaly ur goin to use the je camira efi gear on the 4k to get it running off efi are u goin to use a 4k-e dizzy of just an electronic dizzy keen to see what u do that way always keen to do something different and this is something id do i kno they use these ecus to run all sorts of things have seen one on a 4age. Quote Link to comment Share on other sites More sharing options...
RKE020 Posted June 22, 2011 Author Report Share Posted June 22, 2011 so basicaly ur goin to use the je camira efi gear on the 4k to get it running off efi are u goin to use a 4k-e dizzy of just an electronic dizzy keen to see what u do that way always keen to do something different and this is something id do i kno they use these ecus to run all sorts of things have seen one on a 4age. Not sure on the final out come, SLO030 has an electronic dissy and I have a Microtech so we are looking to do a change over maybe. I have all the wiring from the Camira and we will adapt the Camira throttle body to give us TPS and idle control and use a 4 wire o2 sensor. The trick bit it the fuel pump, I want it in tank no surge tanks in the boot to leak so we will try a VN commodore pump and see how we go....... Our biggest drama is we only have 3-4 weeks before it needs to be running to make the dead line for the boys school project. They didn't say it had to drive but. :dance: :dance: Quote Link to comment Share on other sites More sharing options...
ninja-philbo Posted June 22, 2011 Report Share Posted June 22, 2011 sounds easy enough aye Quote Link to comment Share on other sites More sharing options...
Mick E Posted June 24, 2011 Report Share Posted June 24, 2011 thanks for your help rek020, will check out my wiring.will wait to hear from you about the offset. cheers mick Quote Link to comment Share on other sites More sharing options...
