3Sge Into Ke70?
hey all!
(I'm only planing not actually starting this yet) i saw a picture of a ke with a 3sgeT in it. and got me thinkin what sort of stuff i would need to get the engine into mine? i found out that the engine was from a toyota Hiace.... but that was just a mate tellin me that so idk what year or anything.
if any one could give me a link or if they actually what i would need to do this would be fantastic! (sorry for any bad spelling)
P.S I have a 1984 ke70 with a stock 4K in it. 5 speed manual.
Nothing money can't solve!
Get a post-1998 3SGE as an Altezza half-cut. That way you get all the horrendously complicated wiring loombs and the 6-speed gearbox. It will slot in fairly easiily as it is already RWD and seveal people have done it. Although why you want 210bhp and a smoothly howling 8000rpm in a KE70 I don't know....
If you want something cheaper go for an older MR2 or Celica, but expect plenty of hassles when you try to turn them around.
http://en.wikipedia.org/wiki/Toyota_S_engine
woow thanks guys. but holy cr@p that is a lot of money :S
i have never done an engine convertion before (not hard to tell) and that looks like a HUGE ammount of work for a first time :( does anyone know of something that would be *cheaper* but still gimme some go when i want it?? sorry for the stupid questions :S
Sr20?
4age?
any others??? not to sure about the sr would that be same sorta work lload as the 3sge?
Nothing will fall straight in there except for a K motor. Anything you choose to put in there will require modifications to you suspension, brakes, diff, transmission, engine mounts etc... except for a k motor.
Baby steps first buddy. Wait till you get off your P's.
yeah i was sorta waitin for someone to say that :/ but i do belive your right.
What's the 4K in there like? Good compression?? Bearings good?
You might as well hit it with a cam, some carburation and an extractor system. At least it will be fun to drive while you plan a transplant in a couple of years.
well.... it sounds alright but no tests have been done on it. so idk about the compression. but i think that sounds like a good idea thanks man.
