Mic Posted July 29, 2011 Report Posted July 29, 2011 (edited) RWG - Joel is off 3TC.com Parrot - Ok cool no worries. Thanks again. Sorry for getting a bit side tracked, what I am getting at though, is seeing Ke20 seals aren't available, how much of a task would it to be to modify a ke25/te27 genuine one to suit? Obviously would be a bit of modifying involved. That may be an option for WET.K30. Just an idea. Cheers Mick Edited July 29, 2011 by Mic Quote
GJM85 Posted July 29, 2011 Report Posted July 29, 2011 Considering the quarter window is a different shape and possibly longer in perimeter i'd call it an expesive gamble. Quote
parrot Posted July 29, 2011 Report Posted July 29, 2011 (edited) Agreed, The perimeter is longer so you would need to buy extra seals and attempt joining them. This is my plan with the KE25 boot seals. If necessary, I may try adding in a section to make it work in the KE15. But when the seal is only $USD30, it's worth a punt. Of note, the boot seal provided by the Thai sellers is supposed to suit both KE2x and KE1x Joel is very definitely not Phil's Rotary. Joel runs Toysport in the USA. Edited July 29, 2011 by parrot Quote
