4Age Into Ke70 Wagon
got a 4age ae71 and am keen to put all the running gear into my ke70 wagon... jjst need to know if i need a ae71 wagon diff or just use the ke70 diff (dunno if theres any difference in the two)
cheers andrew
only thing I could see being a problem is tailshaft cause correct me if I'm wrong someone but do panelvans not have s series diffs where as sedan has Borg Warner?
so will the tail shaft out of my ae71 bolt upto my wagons diff?
Have a look and you can let us know! It will take you half an hour.
means i gotta take it out of my track car and then take my wagons one off... pretty sure someone would know on here
80% sure it won't.
Are you sure you're up to an engine conversion? If you don't want to spend the time doing little things like swapping tail shafts then you'll probably get bored of doing all the elongated tasks.
It's not that I don't but its my daily atm and work a lot... Just seeing of anyone knows, would be a lot help...
yeah I reckon ill be fine with the diff I have, just seeing if people out there might know if it didn't fit up, gonna start the swap this weekend
