Ke25 Indicator Problem
ok guys well I picked up a lovely little ke25 tonight, now my issue is that the right hand indicator doesn't flash it just stays on. do I just replace the flasher can thing to fix this? oh and the left hand indicator works a treat?
I tried to look but hard to search RC on an iPhone :( and sorry I'm a bit noob at elec stuff!
cheers abbott
Nope, if the left-hand flasher works, then the right-hand should. One unit does both.
Put the right-hand flasher on and take out the RH bulbs, even swap them with the LH bulbs. If one isn't lit check that power gets there. The flasher unit needs a certain current draw to work.
check your connections on the flasher unit.... mine were slow to flash on my KE11. Shoved the plugs back on harder/better and they flashed correctly. Maybe clean the terminals too, remember these things are near 40 years old
Wrong size watt bulbs will make it not flash
