hey all
I'm half way throught my commodore v6 t5 conversion in a ke70 and I'm havin problems with the tacho dash
i purchesed this cluster last week and installed it today.
i wanted to keep the same cluster for the conversion, ive got all the alt and oil lights and temperture gauge working so far but the tacho has left me stumped
i no ive wired it up correctly but the needle on the tacho wont budge. i no its got a different signal to the original 4 cylinder but atleast the needle should move but be out
ive tryed adjusting the trimpot on the back of the gauge but no luck.
i did test the gauge by using a 12v charger and it did work
I'm so confused why it wont work
if anyone has some suggestions let us no they will be greatly appreciated
i had the same issue when i did the 7mgte conversion in my bundera
basically the tacho in the ke70 is set up for high voltage/output pulse signal, coming directly from the coil
the tacho signal coming from the v6 comes from the ecu, is lower voltage/output which means the signal isn't powerful enough to be read by your tacho
there is a way around it, there is a resister inside the tacho that has quite high resistance, you need to replace this with a lower resistance one, the resister is not hard to find, its the first one in the board coming from the signal wire
i can't remember the ohms of the resister i put in, ill see if i can dig up the info
theres also the issue of the tacho will be reading wrong, it will be getting 3 pulses for every rpm now instead of two, this means the rpms will read higher than actually are
this can be fixed by putting a potentiometer between the two wires that come out of the board to the needle, the +ve and -ve, you will then be able to adjust it to give the right reading
i hope this has made sense, ill try dig up the link, it has pics and stuff, it was for a hilux but should be similar
paul
paul
that helps alot thankyou
ill have a look at the size of the resistor and see what i can replace it with
with the incorrect signal, ino when i had the 12v charger connected to the tacho to test the original trimpot could change the reading a whole 2000rpm but may not be enought
took me a while but found it, obviously not going to be exactly the same as the ke70, but will give you enough to go off
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
paul
edit, maybe thats not it, but found another site that said the new resister should be around 10k ohms
http://i6.photobucket.com/albums/y242/1Thsalvermo/Truck%20pics/Tach-fix-resistor-installed.jpg
Edited by pozman
hey
after a bit of muckin around with resistors i got it working with a 1k0 resistor, the original one was a 39k so it was a big drop but it seems to work really good i just gotta get a digital tacho now to set it
thank for everyones help
