November 7, 201115 yr Author comment_564935 Dunno what pressure mine is getting as my fuel regulator and return is before the carb so I am using a single fuel line on the carby, also check the timing on it when you are playing around with it next. Will need to invest in a new timing light. It "broke". Report
November 7, 201115 yr comment_564955 "broke" :lolcry: I don't have one to borrow any more but if you need to steal parts off my carb to try then I can bring the ute out to you. Report
November 8, 201115 yr Author comment_565122 "broke" :lolcry: I don't have one to borrow any more but if you need to steal parts off my carb to try then I can bring the ute out to you. What size is the motor in ya ute ? i may borrow some bits for testing if ya keen on some beer ? Report
November 8, 201115 yr Author comment_565146 1.8 but it isn't tuned to numbers. Okie dokie. pm me ya number. Report
November 9, 201115 yr Author comment_565280 IT IDLES. Just need to smooth the idle out and its drivable. Report
November 9, 201115 yr Author comment_565293 What was the problem? Its running way to rich at idle and wouldn't run. I'm not going to say how i did it yet because i don't think I've solved the issue but at least i can move the car around. Report
