T50 Into 4K
I have a hydro K-T bellhousing i may sell. If you're keen PM me.
is it fits onto ke30 stock long shaft??
Sorry mate, already sold. And it was just the bellhousing. You'd have had to have bought a t50 as well. T18/ta22 are the same spline as a corolla tailshaft if that helps you.
You need to also convert to hyd clutch,unless you can find a cable type housing,but are very rare.
If you use a ta22 box the shifter position is a perfect fit in to the original hole.
Use the 30 rear cross member,just move it back to the rear factory holes .
Tail shaft will fit if useing the early t50 box.
I had to get longer bellhousing bolts as well,the kt housing is a bit thicker than old k40 bellhousing.
Also need a different clutch plate (PBR-7098W)
Easy job all bolt up the biggest pain is converting to hydo clutch.
No mate not new ,just wire wheel on a drill while drinking beer.
Lots of beer ,beer is good :laff:
