How To Disconnect The Clutch Cable From K40
Hey guys,
I'm in the middle of doing an engine swap on my ke55.
I undid the circlip on the front side of the engine block, and unhooked it from the fork.
But how do i pull the cable through the hole when the big metal hook thing is on the end??
All good guys , i worked it out :)
I disconnected it from the pedal and pulled it through
Hang it up from the roof & put a drop of engine oil down it every time you walk past. When it drips out the bottom its ready to go back in.
To lubricate it?
Yep
makes it easier to slide in and out
Some cables come out from the gearbox side.
Others have to come out by taking it off the pedal and feeding it towards the gearbox.
Will supply pics if I can find em.
Sweet. Well i got it all worked out ;)
My 79 Ke55 had a pin which lets the hook come off and you slide it through the hole.
But my 81 Ke55 i had to remove it from the pedal..
Works great now though
