So,
I'm getting close to finally dropping a 4age into my ke70.
The motor is a small port and currently has a RWD alternator mount (the one under the inlet manifold) and is running the standard 5-rib cogs on the alternator, crank and water pump. The motor will be running without air-conditioning and power steering.
My question is; is there an off the shelf belt to suit my current water pump/alternator set up? Is there a part number? If not, what have you done to substitute this?
Thanks.
Edit: I'm in Brisbane if anyone can recommend any places.
Edited by Gecko71
