Aw11 Lsd (supercharged) Into Ae82 Na
ok, i am looking at buying the lsd box from a aw11 supercharged to fit into my ae82 twinky. i know there will be a prob with the standard driveshafts on my car needing to be changed, and the gear ratios will be different, but will i run into any other problems???
and is it worth it?? loss of power?? etc
thanks
ok, is your ae82 turbo or supercharged?
if not don't DO IT.
the e5# ratios are wider and youll slow ya car down a lot.
i it is turbo etc then yes it will fit, you will need to swap the selectors over to the other side.
amnd play around with ya driveshafts
i think you use the s/c inner shafts and the stock outers
at the moment it is na, hopefully by the end of the year it will be s/c
i can pick up the lsd cheap as because the place that is selling it has no idea that it is lsd
so i guess now my question is, is it worth getting, and then limiting myself to only the earlier model s/c for the sake of lsd when the conversion is done???
front cut with 4agze + lsd = the win
what do you mean limiting ya self to the early model s/c?
if you get that box it will only suit forced induction
i was planning on supercharging it later this year
but i have been told that if i plan on using that box i can only use the early model supercharger with it, not the later 130kw one................. is that wrong??
yes. totally.
id be interested as to the reason given for that!
lol, lets just say it came from somebody with a ze in there ae92 looking for an lsd also!
they also told me i would never find the driveshafts so it was useless! lol
thanks for the truth! :harhar:
Grrr I hate people that do that...You should slap them about the head with a smelly tuna
yep, kick em.
as for the shafts.. look into it a bit more.
i can't recall for sure if you can use 1/ 2and 1/2
