New To The Site And Have A Few Questions
hey guys I'm new to the site and just got a t18 with a 16v redtop and have a few questions about it.
i have a ticking noise when eva i accerlate. is that normal or is there something rong??
what should the idil revs be for it??
and what is the aver temputure for the water and also the oil presuure in the engin??
I feel like i am reading a text message.
Please try to use proper grammar and wording or I can almost guarantee you won't get much of a response from members.
Ticking noise from.....where? :blinks:
Idle for a 4AGE is ~850rpm, model/transmission depending.
Oil pressure (engine at operating temperature) should be 30kpa (minimum) at idle & 250 to 490kpa at 3000rpm. Coolant temperature, NFI, too many variables but apparently the thermostat opens at 82 degrees celcius.
Welcome aboard but, man, my head hurts.... :(
1.2.0 Before starting a new topic do a search where necessary to see if it's been covered before. If you can't be bothered to help yourself, niether can we. You may recieve warnings if you don't search.
1.5.0 Please read your post before you hit the button. Post as much information as you can so people know what you are on about. Check your spelling, you will be visited by the spelling fairy (pictured below) if you repeatedly ignore requests to fix your spelling. Occasional slip ups are fine, we're not perfect, but at least try and make it look like you passed english.
2.2.0 Research your idea/conversion/problem first. Its quite possible it's been covered before either on rollaclub or somewhere else on the web. If you show absolutely no signs of having researched you probably wont recieve any replys and your thread may be locked by a moderator/admin asking you to do some research and try again. We're not here to serve up answers on a silver platter. We help those who help themselves.
Broken ring on a piston. It fails to hold the piston steady and you are hearing the tick of the pston slapping in the bore as it changes direction.
Otherwise we need more info about what happens to the tick when it idles, (could be tappet) or the timing.(could be pinking)
..and we need it in English.
n
Edited by frosty
