March 18, 201214 yr comment_591122 Hi guys, in my ke30 fuse box the 15A fuse labelled "engine" keeps blowing, and my charge light is staying on, is there something related between the two ? and what does the "engine" fuse connect to? cheers all! Report
March 18, 201214 yr comment_591134 Find a wiring diagram for the KE30 on google images or similar and trace it on there. Does the fuse blow when you turn the ignition on before you start it? or as you start it? or later on when driving? Take the wires off the alternator or take the fan belt off and see if the fuse blows when you run it for a minute.. Strip the alternator & check diodes, windings and brushes, that will be causing it not to charge. I don't know if it is also blowing the fuse, but that 'engine' fuse might be the 'altenator' fuse on my diagram. Report
March 18, 201214 yr Author comment_591150 seems to blow before the engine starts, just when the key is in on position. will try trace it back cheers Report
March 24, 201214 yr Author comment_592298 replaced voltage reg and fuse still blowing anyone got any ideas?? Report
March 24, 201214 yr comment_592356 replaced voltage reg and fuse still blowing anyone got any ideas?? Put a 30amp fuse in it... Report
March 24, 201214 yr comment_592368 You will need a wiring diagram really. Try tracing the wires from the ignition switch down to the engine, they obviously power the fusebox, instruments, alty & coil, and something must be shorting out. Anything that livens on "igntion" and not just "accessories", so indicators would be another one. Just start disconnecting things on that line until it stops blowing a fuse, although I'd strongly suggest you buy a $10 multimeter and just check for ignition going to earth each time.. There are diagrams on the web. Report
March 29, 201214 yr Author comment_593431 ok so late reply. but after mucking around a bit, i found that if i unplug the voltage reg but keep the alternator all hooked up the fuse wont blow, however as soon as I connect the voltage regulator the fuse blows again! Report
March 29, 201214 yr comment_593472 Grab a voltage reg from a wrecker and try that. Even if you can take your one apart you might see what is wrong or burnt out. Report
March 29, 201214 yr Author comment_593586 Grab a voltage reg from a wrecker and try that. Even if you can take your one apart you might see what is wrong or burnt out. This is a new reg i got it last week. Could the wiring i. It be different? Report
March 30, 201214 yr comment_593629 Could the wiring be different? [/quote Unlikely, it sounds like you had the same problem with the old regulator, is that right?? So neither reg is to blame and the problem lies elsewhere, unless both regs were crook in the same way. Let me make you a wiring diagram... OK, power comes from the battery through the fusible link along the yellow dotted line to the ignition key. You can see that the alty feeds into that line to charge the battery through it. The key works the ACC at the top, then the IGN position next down. That sends the power along the blue line to the 10Amp engine fuse. From there it goes down the black-spotted green line to the ignition light, and then to the alty fuse and the alternator. If the alty is working fine current flows & the light glows red. It also powers the fuel cutoff solenoid on the carb. I don't think you have one... Then it continues along the top of the diagram to power the dash instruments like the oil pressure circuit, handbrake light, etc, & powers the wipers & indicators. Eventually it turns on everything that works when the key is on! So, what else is killed dead when you disconnect the voltage reg?? Do all these other circuits still work, or is the problem in one of those and killing the reg takes the problem circuit out too?? Somewhere you have a problem in that circuit, something is dumping the electricity straight out to earth and blowing the fuse. You'll have to put a multimeter over the wiring to see which part of it has a path to earth. If you blow this image up you might be able to read the colours of the wires, but it ws a pretty bad scan to start with. Also, its for a KE70 so it has a built-in regulator in the alty, but it gives you an idea of what happens. :: SIGH :: can't get given beers over the internet Edited March 30, 201214 yr by altezzaclub Report
April 1, 201214 yr Author comment_594122 thanks altezza club, i will have a probe around, it has the same prob as before i replaced the reg, and when the fuse blows everything on the ACC circuit and ON circuit still seem to run, jus the charge light stays on and the alt wont charge Report
April 10, 201214 yr comment_596414 I had this same problem and it turned out to be a loose wire every now and then touching the positive terminal on top of the alternator and shorting out. check around that area would be my guess Report
May 31, 201214 yr comment_607189 U have a short somewhere never I repeat never put a bigger fuse. In unless u won't your car to burn Report
