March 22, 201214 yr comment_591925 alright. i got jipped a while back with buyin a pair of lcas. they came with new rubbers and you ball joints. and sprayed black so they hell Overrated. BUT there was no outer sleeve. no outer sleeeve no lac's for meee does anyone either have.. or no where i could get these "outer sleeeves" cause i am totally stummped :/ Report
March 22, 201214 yr comment_591941 The metal sleeve part that the rubber bushes sit inside at the crossmember end. Ke70 ones not fit?? i thought, since the xt130's fit a ke70, the sleeve may be the same? Report
March 22, 201214 yr comment_591959 Oh yeah I know what ya mean now, any suspension shop should be able to find it for ya man aslong as you take in all the details or better yet take the lcas in and get them to find something to fit!!! Report
March 23, 201214 yr comment_592045 I would be sick of it, just take them to a suspension place and say make these bushes fit these control arms. Report
March 23, 201214 yr comment_592047 or if you can't buy it from a suspension shop, go to the wreckers and climb under any old RWD toyota you can find and find something that is the same. it is only the lenght and ball joint compatibility that makes the xt130 control arms so saught after. the other end, i hypothesise, is the same as a stack of other cars from the same era. Edited March 23, 201214 yr by ke70dave Report
March 23, 201214 yr Author comment_592159 alright well i rang my buddy at some parts joint. and hes havein a look too see. so if that is no good ill give a suspention shop a go cause they should be able to do it ;D cheers fellas Report
