Got everything to get engine running, radiator from the lexus just fits, got all wiring, ecu, even throttle cable everything to get it running!
Car also had full service history with only 165000kms on the clock.
it was a body damaged supra that got me on this train of thought, it was $2k and running. I was originally going to go with a turbo 5k.. and have most of the bits for it.. but i thought hard about it, and I don't think it will keep me happy for long.. I have a worked vr4 galant, and have considered using the turbo 4g63, and selling the rest as parts.. I dunno, maybe i'll just do a turbo 4ag like everyone else.. or maybe i'll just sell all my shit and buy one already done..
I was only asking about the engine, and i want to start with the engine. I do not see the point in building the car, suspension, brakes, etc, get it all sorted, then throw everything out of whack because i put another 100 kgs into it.
My KE70, to which i am fitting a turbo 18RG (yes silly idea but meh), has to date cost me around $10K doing nearly everything myself.
If i could weld, i would have saved around $1500 of that.
I still have around $3k to spend to get it running.
... and I'm doing things quite frugally.
yes you could spend just $2k on the engine.... but where you will burn double that sum is:
- diff
- tailshaft
- gearbox
- gearbox tunnel mods
- radiator
- fuel system
- crossmembers and engine/gearbox mounts
- sump modifications
- intercooler piping
- exhaust system (and most likely a turbo manifold that will FIT in your engine bay)
- etc etc
.... and thats even if you do things on the CHEAP.
Ive done enough conversions in my time to know these things are not cheap.
- diff
- tailshaft
- gearbox
- radiator
- fuel system
- etc etc
Listen to this man ^^^
... yep.... and i havent even started on the less than lucklustre standard braking and suspension fitted to the KE20.
There's another $2-3k there if you want to play at sprint/track days and be able to actually stop the car in less distance than an A380 landing at sydney airport.....
EDIT: i can't speel
Edited by the witzl
ok so i have found a vr v6 with 105000kms on it complete car minus front struts. $600. still considering whether i want that engine plus it's auto :/
that would leave me $1400.. think i would prefer a ca18det tho.
i wont be buying a halfcut. I will buy a whole car, damaged or not, take what i want and part out the rest. I will get it done in less than $2k.
Post up a build thread once you've made your decision and prove it then. Dude, buying a wrecked S13 is going to cost you close to 1000 if not more, even just having a tailshaft made is going to cost you around the 400 mark, shortening a diff to go with it, suspension, brakes, intercooler piping, the list just keep going.
God damn,
Doesn't anyone else do a complete rebuild of the engine before they stick it in a car?
I got my block tested, head tested, new bearings, complete gasket kits and so forth before I even started at looking at anything else,
My situation was going to be high boost application but still its better safe then sorry and not have doubts everytime you drive your car.
Just to do that alone, if you don't have connections could cost your $2000 (using well known parts not cheap ebay crap eg bearings etc)
I would have thought someone would of added that into the discussion, doesn't matter if you have it fitted everything else in for your budget and the car dies first time its boosted/hits redline etc.
Edit: Yes I know you can look at the condition inside of the engine, but I still feel better replacing everything anyway.
Dave
Edited by Stenzel
I'm just speaking about getting the engine completely into the car and have it ready to be driven. Nothing else. That alone will be out of his budget.
I wasn't calling out anyone Willis,
I'm just saying my opinon to OP
Do it right and do it once.
But if it is going to be a bush basher then I guess who cares doesn't matter if it fails after your second drive.
Edited by Stenzel
