Ae92 Driver Window Broken, How To Fix?
my driver window RH side has been stuffing up. when it winds down, it pops off the rails then winds up on a angle. it doesnt slide up into the spot it is meant to unless i guide it. some times it just gets to a point where it wont go up or down. its a manual winder and the tab where the front arm connects to has broken off but i have zip tied it to the point that it is in the proper spot. if anyone can help out in any way, i'd appreciate it. i want to get tint but not if the window keeps playing up. if you need photos or a video, ill do my best to grab them. just want this window fixed so i can use it when summer comes around and i can get my windows tinted. thank you
Link to comment
Share on other sites
  • 2 months later...
  • 9 months later...
I am having the same problem as Scotty.bmx with my AE92 corolla. My driver's side window becomes twisted and pops out of the mechanism that winds up and down. I took the door apart and put the window back in the slot at the top of the winder mechanism. It worked for about a week and then the original problem happened again. There doesn't seem to be anything holding the window to the winder mechanism except the rubber lining the slot at the top of the winder. Also, The window doesn't slide smoothly up and down in the tracks in the door. Can the tracks be lubricated in some way?
Any suggestions on how to fix the problem?
Link to comment
I haven't really looked into this but would a new window regulator help ?
http://www.ebay.com.au/itm/Toyota-Corolla-Seca-Front-Right-Window-Regulator-89-94-/130521038879?pt=AU_Car_Parts_Accessories&fits=Plat_Gen%3AAE92&hash=item1e63a9001f
You can use lithium grease on the tracks, but best to check what kind of grease is already on there. white/dark/creme colour ? Its not good to mix different types of greases together.
Link to comment
