scotty.bmx
Everything posted by scotty.bmx
  1. i found a set on ebay for like $400. don't know how good they are but they are coil overs... and my car sits low with the king springs in, i can't imagine anyone wanting to go much lower
  2. my mate gave me his ae101 sway bars as he is moving and i was wondering if i could put them into my ae94 corolla? any help would be good thanks
  3. this is what i have in my ae94 sedan: http://www.ebay.com.au/itm/TOYOTA-COROLLA-AE-92-93-94-F-R-SUPER-LOW-COIL-KING-SPRINGS-/150666628154?pt=AU_Car_Parts_Accessories&hash=item23146e4c3a#ht_942wt_1037
  4. can i use interior parts from my ae95 wagon to put into my ae94 sedan? (seats, dash, trims including door trims) and the front bumper, will it fit/bolt straight on? thanks
  5. sorry for the late reply. here is the link again to what I'm in possesion of for my central locking. it isnt one like rian has, its a stock type so that has made me more confussed. still no instructions found to install http://www.ebay.com.au/itm/Toyota-Corolla-AE92-94-Complete-ORIGINAL-Central-Locking-Unit-MUST-HAVE-/110862671985?pt=AU_Car_Parts_Accessories&hash=item19cfee2071#ht_926wt_1037
  6. yeah that helped. as i said, ive tried to fix it but not having the outta chrome trim on the door on my window makes me wonder if thats the reason or not
  7. will hatchback parts fit on a sedan? (bumper, door trims)
  8. my driver window RH side has been stuffing up. when it winds down, it pops off the rails then winds up on a angle. it doesnt slide up into the spot it is meant to unless i guide it. some times it just gets to a point where it wont go up or down. its a manual winder and the tab where the front arm connects to has broken off but i have zip tied it to the point that it is in the proper spot. if anyone can help out in any way, i'd appreciate it. i want to get tint but not if the window keeps playing up. if you need photos or a video, ill do my best to grab them. just want this window fixed so i can use it when summer comes around and i can get my windows tinted. thank you
  9. Its a AE92 sedan and there were no instructions included
  10. So i bought STOCK central locking off buytry1 (eBay user) and i have no idea on earth how to install this. I have no idea what part goes where or ANYTHING AT ALL if someone has previously installed this kit into their car, or knows where a write up is online or step by step OR they can write a step by step now, id appreciate it so so much. I'm utterly confused and I'm not going to rip my car apart when all it should of been was a simple install. thank you!! http://cgi.ebay.com....em=110862671985
  11. thank you, all i know its a ebay item going onto my 93 AE92, don't really know the difference of series 1 & 2....
  12. will a front bar from a ae90 fit on my ae92 sedan? cheers
  13. turns out the gearbox had 0 oil. the drain bolt had fallen out so it was driven to bone dry :| all sweet now though!!
  14. the noise is there when accelerating and when not accelerating ONLY when then clutch is connected. when i push the clutch, the noise dissapears
  15. So a month ago i had a new clutch installed into my AE92 corolla. The car has been running fine since then but it has always 'stuck' in third gear when i tried to shift gears (it wouldn't come out unless force was applied or several light attempts). This didn't bother me too much but today it started making a whining noise while driving in third gear so I avoided third gear to save myself from that problem. Me being me, instead of not driving for the weekend and taking it to my mechanic on monday, i have been driving around all night and now every gear makes the same noise and its starting to get real rough changing gears. it is a struggle to get into reverse and 1st gear. The noise is best described as a V8 supercar accelerating. that whining noise (but sadly without the V8 power). so my question is, gear box oil? replace the gear box? some post online suggested the 'clutch release bearing' I have no idea, and would like to buy a 2nd hand gearbox from the wreckers ASAP (or anyone that has a 5 speed gear box with low kms for a ae92 fuel injected 16 valve), or a answer so i know its just as easy as putting gearbox oil into it. Any help at all would be great, thank you!! If needed, i can make a video or the sound and post it online so you can hear for youself (if the video picks up the sound)
  16. so i just bought a 1993 corolla sedan and the only thing wrong with it is that the radio doesnt work, the clock doesnt work and the interior light doesnt full power up while on door mode and a door is open (some time it doesnt work at all when a door is open). i checked the fuses and they all seem to be good. any ideas would be good as i want to upgrade head units but not untill i know the wires work properly.
