Ok so i did a 4k engine swap in my ke70 as the other 4k died and switched the carb and fuel pump as they were in better condition.
Well i got the timing done and vacuum lines all hooked up. And when the car is warm sounds like it idles around 1k-1.5k rpm and when choke is on the car shakes like its running rich and dies within a few seconds. I'm leaning towards air fuel screw if anyone could help me locate these screws or have any info on what else it might be let me know. Thanks.
I think they're on the rear of the carb, passenger's side, although its a few years since I had a stock carb around.
Just follow the throttle cable, it will lead to the idle speed screw and the idle mixture screw will be nearby. Make sure the choke isn't holding the idle on when the motor is warm, or maybe the choke cable is set up too tight.
Does it do eveything else as it should?
Altezza - car druves as it should. Just if I'm in gear and let the rpm go down low to like 800 or so and pull the clutch in just goes high again. Sounds ugly lol. I can pretty much take off without throttle. Ill double check that the choke isnt tight and get back to you.
Alright so i fixed the idle problem. The throttle was open a little because of that bolt with a spring under where the fuel goes into the carb, was on tight. But still the problem when i turn on the choke full it shakes and dies. But if i leave it halfway it seems to function as if it were fully open.
Any tips on what i should do about the choke stalling on me when on full and functioning properly when its half way
Take another look at the choke mechanism. It does two things, holding up the idle speed and also richening the mixture with the flap over the carb throat.
I can't remember how they interact and how adjustable they are, but my SUs just hold the throttle open until the chokje is halfway out, then pulling the choke further actually richens it. That interaction is quite adjustable.
Find out if it is closing the choke flap immediately you pull the choke knob, and if that can be altered. I've got my old carb out on permanent loan so I can't go and have a look... Stick up a couple of photos of the choke setup if you get stuck.
