salman Posted November 23, 2012 Report Share Posted November 23, 2012 Hi all, i was running 3k in my starlet, i saw 7k at my friends place and bought it, in exchange i gave 3k to my friend, ... I thought is bolt on .. :( but found out the swap issue,... I Do have a 2k ... Now I want to use the 7K with its original Oil pump ... ?? please help me out here. Many thanks... Salman Quote Link to comment Share on other sites More sharing options...
Bowler Posted November 23, 2012 Report Share Posted November 23, 2012 Have a read... http://www.rollaclub.com/board/topic/16660-matts-7k-ke30/page__st__210 He's done it with plenty of detail. not sure about the starlet cross member, but can't imagine it being much different... Quote Link to comment Share on other sites More sharing options...
salman Posted November 24, 2012 Author Report Share Posted November 24, 2012 He modified the Sump. let me see.... i can't find the pictures.. Quote Link to comment Share on other sites More sharing options...
78_7kRolla Posted November 25, 2012 Report Share Posted November 25, 2012 He modified the Sump. let me see.... i can't find the pictures.. I really don't have any decent photos of the sump mods. As you can't really see it behind the crossmember. Basically you just have to scallop the sump around the crossmember on the passenger side. Quote Link to comment Share on other sites More sharing options...
salman Posted November 26, 2012 Author Report Share Posted November 26, 2012 The main issue is Steering rod connecting to the steering rack, , My StarLet is RHD. Quote Link to comment Share on other sites More sharing options...
78_7kRolla Posted November 28, 2012 Report Share Posted November 28, 2012 If you are already running a k-series motor then it shouldn't be an issue as the block is only marginally wider and taller. Quote Link to comment Share on other sites More sharing options...
salman Posted December 1, 2012 Author Report Share Posted December 1, 2012 I have the 3K stater motor, the engine didnt came with one, its not cranking the engine... taking load... as when the battery is low. .. , :offtopic: Quote Link to comment Share on other sites More sharing options...
salman Posted February 10, 2013 Author Report Share Posted February 10, 2013 Hi all, Sorry, was busy. The issue i had with cranking the engines, was because of starter motor, i was using 4K starter motor which was unable to rotate the 7k-E , alltho it was New! I Searched and found a 7k with starter motor, it was totally different thing, Installed it and the engine started to crank perfectly,. then the IGN timming : have to Learn and redo the IGN timing, read an article here and done. the only thing which bugs me Now is exhaust pipe, currently i have 1.5 inch Straight pipe till to cylincer and nothing in between.. I just want to know what the recommanded exhaust setup for 7k-E.? also a friend of mine have a t50 (20 spines) available, which he had in his 4age Silver top. can i use that tranny in 7k-E. > Thanks Quote Link to comment Share on other sites More sharing options...
