How To Make Ke70 Adjustable Trailing Arms?
wondering if anyone has made adjustable rear trailing arms before, and how to do it?
Or if anyone has some for sale
Yeah I've got some that I'd like to sell, haven't yet advertised them. Tune Agent branded and in good nick. PM if you're interested.
Otherwise, there are a lot of trailing arm kits on ebay if you're handy with a welder. They consist of a bung as well as the rose joint. You'd probably have to fabricate some spacers, but that wouldn't be too difficult.
ive made on car adjustable arms ..
its easy
camry arns into cut.n.shut ke 70 arms
I've got whitline uppers, no problems. Terry, elaborate on your arms!
camry rear arms are on car adjustable
with a little work they fit inside ke70 arms
making cheap on car adjustable arms...
ive made both upper n lower as well as panhard rods.
Is this to correct the diff angle when you lower the car? How low would you have to go before you need to alter the stock ones?
allows for pinion angle as well as centring wheels in the arch
