February 8, 201313 yr comment_646702 Hey guys! I have a ke20 with T series engine mounts and W series gearbox mounts. What's the best gearbox should I use with a 3tc? Like which W series? And will just bolt up? Thank you. Report
February 8, 201313 yr Author comment_646712 I'm assuming the 3Tc had a w55...I am new to this from what you've already assumed haha Cheers Report
February 8, 201313 yr comment_646716 don't think the 3tc came with a w box i know the 3tgte did but i know u can use a 1ggte w58 box as it bolts up no worries Report
February 8, 201313 yr comment_646733 Yes and you can also use the later aisin j160 six speed from an Australian delivered is200 that came behind a 1g. G and T engines share a bellhousing pattern. Or like others said, you could also use a 3tgte box or a soarer one. This would give you a w 55 or 57 or 58 box. Report
February 9, 201313 yr Author comment_646802 Aww very true! Thanks for the info guys! I think ill be heading in a w55 or 57 or 58 depending on availability really. I'm not aiming for massive power. Report
