Hi Brendon,
Common fault with the olde KEs. The usual cause is the tiny 8-9V voltage regulator on the rear of the dash printed circuit board behind the guages, or the "sender unit" in the tank itself. Very rarely is the cause the guage itself. I assume you have checked all the fuses first.
I'll see if I can't dig out the circuit for you.
Cheers
Banjo
Pull the sender out and check it with a multimeter. Resistance (ohms) should vary as the arm goes up and down. If that's good then work your way forward to the gauge as above.
Sometimes the sender floats get holed and fill up with fuel.
  • 4 weeks later...
yeh cheers guys for the helpmite have to take you up with some parts as well if its no trouble. turns out my speedo is stuck at 45 but still sorta works i think and my temp gauges seams to be failing as well
