April 25, 201313 yr comment_654261 Hi Everyone, I'm wanting to convert my 4K to electronic ignition. I've got the distributor, I just need a diagram for the rest of the electronic ignition setup if anyone has one. Also, would 3K, 4K, and 5K need different setups? Cheers, Josh. Report
April 25, 201313 yr comment_654266 http://www.rollaclub.com/board/topic/46089-how-to-install-an-electronic-distributor/ Report
April 25, 201313 yr comment_654270 I'm not sure if yours is the same as the one I fitted, but it was dead simple to wire in then terrible to drive. If you get less performance from the electronic dizzy then it will be an advance weight problem. Starts here- http://www.rollaclub.com/board/topic/42407-the-girls-ke70/page__st__45 and links to this- http://www.rollaclub.com/board/topic/49927-how-to-fix-your-brand-new-ke-motorsport-electronic-distributor/page__pid__511594#entry511594 Report
April 25, 201313 yr comment_654282 easy. black wire to original dizzy wire. black and orange wire to positive coil. Report
