July 6, 201313 yr comment_661015 Will post pictures of my build as I go but as it stands I have the donor car (2001) VX supercharged v6, looking at a KE70 tomorrow fingers crossed :) Report
July 7, 201313 yr comment_661057 Goodluck with the build mate Mines being going for a year or two now. Still not done but getting close Only real problem that's a pain is the extravtors are right at the steering so you need to cut and angle it and bend around it. Itherthan that its pretty straight forward Report
July 7, 201313 yr Author comment_661070 Here's a pic of the new "heart and soul" just replaced the fingered harmonic balancer will give her a clean up once I yank it out. Edited July 7, 201313 yr by KE70 SV6 Report
July 7, 201313 yr comment_661099 I havent looked at a KE70 rack and steerign column too hard, But if you are having trouble with clearance, you could always add a few steering unis to get it to "bend" around what you need. Otherwise, the other trick is to offet the column (so redrill holes slightly over) and move the whole lot an inch whichever way you need to. obviously its a bit of work, but if it gives you the clearance to run of the shelf, or bigger pipes, it would be more than worth it. Report
July 9, 201313 yr comment_661245 I thought about that with mine but I found it easier to modify the extractors. Didn't need much just added a slight S into them to space them out wider. Made sure to do both sides so their equal still. Havnt finished them waiting till I put this ecotec in and will finish it all up Report
July 20, 201313 yr Author comment_662302 slight change of plan the KE70 fell through I ended up buying myself a suzuki Mightyboy Report
July 29, 201313 yr comment_663178 slight change of plan the KE70 fell through I ended up buying myself a suzuki Mightyboy Report
July 29, 201313 yr comment_663205 http://www.icbm.com.au/mightyboy/v8.htm Last i heard it was running the streets of Alice Springs with rego. That was decades ago but. Report
