3K Carby On 4K Problem
hi guys i have a ke70 that has a 4k in it, it is running a 3k carby. the problem is when the car starts cold it is fine, but upon warming up it stalls on idle and at traffic lights and such, i am kind of a noob when it comes to carbies and have been searching for a solution. any help is greatly appreciated :y:
Check the points gap and timing too.
As the points age they wear so the gap gets smaller and that retards the ignition timing, which makes it idle slower. Make sure the gap is correct then check timing.
A dwell meter is more accurate than feeler gauges, if you have one.
I put a 3k carby on my old 4k. I'm not convinced the standard 3k carby and/or carby jets can supply enough fuel for a 4k.
Mine was soooo slow. Howe ever it didnt use much petrol!
Perhaps it might be worth swapping in the jets out of a 4k carby into the 3k carby, its essentially the same carby so shoudl bolt in no worries. i was going to do this, but i fixed the 4k with a 4age.
and, like jasonke20, check the venturi sizes in the throats to see if the 4K flows more air than the 3K.
Lol- the ultimate solution!
4age is in the works lol
cheers for the replies i will google all those unfamiliar words and see if it works :hmm:
