Ke70 Lower Control Arms
Hey guys I've heard a few things about putting ke55 lower control arms in a ke70 which give you a bit of camber but its not over the top like xt130s and sigma Lcas. Does anyone know if ke55 ones will bolt straight up or what I'd need to make them fit? Would rather see if someone had done it before i start tryin myself
Cheers heaps
More research needed. Can you get some measurements on each of the types?
Coronas are shorter than Sigmas, and they bolt straight into the KE70 to give zero camber, (well, minus 1/4deg) and the KE55 are the same as the Corona
Sigmas are pretty extreme.
http://www.ae86drivi...php/t-2205.html
Here is some classic forum conflicting information.
but if you read between the lines it seems the ke30/ke55 is pretty close to the beloved xt130 LCAs.
I am amazed at how much people will pay for xt130 control arms.
also
http://www.rollaclub.com/board/topic/38573-tie-rodtubeke70ke3x5x-faq/
Edited by ke70dave
