August 27, 201313 yr comment_665641 Hi guys I'm currently building a ke55 4dr sedan Just resprayed it a nice orange pearl An now I'm at the stage of installing the auto gearbox back upto it cause the original blew up Problem is everytime i get to a certain point on toghtening it up to the engine it locks so i can't turn it over from the bottom end on the block Can anyone help me with this issue ?? Stall convertor is in so it can't be that its not all the way in any other suggestions Report
August 27, 201313 yr comment_665684 Is the gearbox in neutral? I remember puting a Borg Warner 35 into my cortina years ago and it was a bitch to line up too Report
August 28, 201313 yr comment_665723 Torque converter needs to be all the way in (if I interpreted your last sentence right), could be your problem as it is causing things to sandwich, cheers! Report
September 2, 201313 yr comment_666044 Need the pegs on the front of the converter to line up...can be rather tricky Report
