hey guys iv got a worked 20v silvertop ke70, will be running a haltech e11v2. are there any good tuners in BRISBANE who have worked with 4age's ? (101 performance ʞ©$ɟd me around so not going there). iv heard pits on the goast is good but prefer dynoing here saves me forking out shit loads of money for a tow.
What part of a dyno shop are you after?? Re-map for afm? Power runs for timing setup?
I'm just wondering how hard it can be to do it yourself... There must be data-collecting software that will record air/fuel ratios from the oxy sensor, injection cycles for the injectors and ignition timing while you blast up a hill on full throttle. A smartphone will give you acceleration rates and then power in KW.
