October 20, 201313 yr comment_669753 So i have a ke70, think its an 84 but not sure, i use the car to smash about in because i Have a fair bit of land. Was going fine, had headlights on, then nothing. Now i am missing Headlights Hazards (but indicators still work) Interior light (but door light works below dash) Dash lights are out (but batt, oil and handbrake lights come up) Tail lights but no reverse lights No horn Windscreen wipers and washer bottle work So yeah help me out? I have tried everything and nothing so far Report
October 20, 201313 yr comment_669762 Check the fusible links near the positive terminal on the battery. There are 3 wires there, and one of them powers all of these things. Edited October 20, 201313 yr by rian Report
October 20, 201313 yr Author comment_669772 Hey rian, I did think this also but i replaced my fusible links with modern ones already, all fuses are intact still Report
October 20, 201313 yr comment_669779 Well the problem has to be somewhere between the fusible link and the dash controls, there's only 1 wire that supplies power to all the things you mentioned. You'll need to get a multimeter/test light and find out where the circuit is broken. Report
October 21, 201313 yr comment_669828 Have you got a wiring diagram Brad? There are some up on here, and that will show you what joins to what. Report
October 21, 201313 yr Author comment_669854 I have a wiring diagram might have to look it over nice and hard and check everything again. Ill check again with a multimeter and post up if i have any luck! Could going over a nice bump have done anything obvious? Report
April 25, 201412 yr comment_681705 i lost circuits for running my car. in the city. after a nice bump. stood there gawkin under the hood talkin to her there was a multipin connector starting to come loose. sliding apart. it had a black sheath covering it to keep water out. reaching down by the main harnesses i caught hold of it and put a plastic tie on. encircled it between the wires on each half. restored the connection. and " vroom vroom" i have a 3K in a ke20, 74 in usa. i don't know every circuit it feeds, but they were mains. the sheath covered it so well i had to be standing and leaning in and turning my head to see it Edited April 25, 201412 yr by dannyl Report
