So i have a ke70, think its an 84 but not sure, i use the car to smash about in because i
Have a fair bit of land.
Was going fine, had headlights on, then nothing.
Now i am missing
Headlights
Hazards (but indicators still work)
Interior light (but door light works below dash)
Dash lights are out (but batt, oil and handbrake lights come up)
Tail lights but no reverse lights
No horn
Windscreen wipers and washer bottle work
So yeah help me out? I have tried everything and nothing so far
Check the fusible links near the positive terminal on the battery. There are 3 wires there, and one of them powers all of these things.
Edited by rian
Well the problem has to be somewhere between the fusible link and the dash controls, there's only 1 wire that supplies power to all the things you mentioned. You'll need to get a multimeter/test light and find out where the circuit is broken.
I have a wiring diagram might have to look it over nice and hard and check everything again. Ill check again with a multimeter and post up if i have any luck! Could going over a nice bump have done anything obvious?
  • 6 months later...
i lost circuits for running my car. in the city.
after a nice bump. stood there gawkin under the hood
talkin to her
there was a multipin connector starting to come loose. sliding apart.
it had a black sheath covering it to keep water out.
reaching down by the main harnesses i caught hold of it and put a plastic tie on.
encircled it between the wires on each half. restored the connection. and " vroom vroom"
i have a 3K in a ke20, 74 in usa. i don't know every circuit it feeds, but they were mains.
the sheath covered it so well i had to be standing and leaning in
and turning my head to see it
Edited by dannyl
