November 11, 201312 yr comment_671560 hi guys I'm doing a ke70 4age tvis map sensor so its been to the auto elects and got all wired up and now i need to get it going it has it all injector pulse , spark, fuel .. sooooo i the motor i got had the dizzy 180 out turn it around and timed it off the wrong case marks but found out it just need to be facing upwards.. if i spray a tiny bit of start you bastard it chimes right up and idles but at like 2500 rpm and that ... if i touch the throttle body it dies so if i try and rev it . it dies ... i don't know what the problem is .. if anyone can help please kind regard locky thank you Report
November 11, 201312 yr comment_671562 First thing I'd check is that you have a "start" signal from the ignition barrel to the circuit opening relay for the fuel pump. Then I would check for vacuum leaks, it's either that or the timing which is causing the high idle rpms. Report
November 14, 201312 yr Author comment_671792 thanks for your reply sorted my sh*t out it was only 1 of the 2 blue injector wires was running the signal wire hooked both up away she ran.... Report
November 14, 201312 yr comment_671813 Nicely done. How much money did you pay an autoelectrician to wire your car and for it not to be running when he finished? Report
