rallydad Posted December 10, 2013 Report Share Posted December 10, 2013 Hi all, Found a complete silvertop 20V 4AGE with loom, ECU and 5 speed RWD gearbox and bellhousing to suit. No clutch, crossmembers or dizzy relocation setup. Assuming it runs well, whats it worth? I have bigport 4age with T50 gearbox currently installed and running well in AE71 club car used on dirt. Is it worth the drama to upgrade? Cheers Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted December 10, 2013 Report Share Posted December 10, 2013 More power is always worth it, but the stock ecu will be no good to you, you need to run an aftermarket ecu and use a map sensor to enable dropping of the airbox. Quote Link to comment Share on other sites More sharing options...
rallydad Posted December 11, 2013 Author Report Share Posted December 11, 2013 It has AFM included in loom... Use with custom airbox and I can use standard ECU? Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted December 11, 2013 Report Share Posted December 11, 2013 You still have the distributor that hits the firewall. Quote Link to comment Share on other sites More sharing options...
rallydad Posted December 11, 2013 Author Report Share Posted December 11, 2013 Ah yes that is true.. Think I'll stick with the BP for now. Quote Link to comment Share on other sites More sharing options...
