July 7, 201412 yr comment_685277 Complete ae82 minus gearbox, engine, front seats and wheels part from that it has exforce exhaust with extractors, full ae101 front end with lowered Lovell springs. Edited July 7, 201412 yr by rolly Report
July 14, 201412 yr comment_685521 do you still have the shiftknob, sunvisors, rear view center mirror, and center console box ? Report
September 22, 201412 yr comment_688591 I might be interested in drivers door(no mirror), rear passenger door, door trims, rear axle(if disc) tacho dash, pm me prices and i'll get back to you. also where in vic are you located? Report
October 9, 201412 yr comment_689265 i'm chasing 0.75 ratio 5th gear pair. supposedly found in C51,53,57,58,59,151,153 & 156 boxes. The most common application was AE101 corolla. I will consider buying a complete box if necessary its easy to check the ratio, remove the 5th gear cover and count the teeth. probably 40 x 30 teeth to give 0.75 ratio pM here or text me on 0417-687161 and i'll text or phone back. thanks, Terry Report
November 9, 201411 yr comment_690430 Hi, I'm after the front corner lights. Do you ship to Belgium? Report
