Ke70 Engine To Gearbox Compatibility
I don't think so, the K series was discontinued as a unit, neither motor nor gearbox was worth putting onto something else. You'd blow the K gearbox up with much more torque I expect.
Start looking for a T-series gearbox and an A series motor if you want to modernise. The T50 gearboxes were behind the Tseries motors and then carried over to the more modern A series engines.
