Benny boy Posted September 22, 2014 Report Share Posted September 22, 2014 Hey I'm new to this te stuff just wondering if I can use te struts of some sort hoping te16 to put in our ke70 if so do they take wider shockers such as ae 95 or ae 86 as bought koni adjustables to suit a ke 70 but they too wide for the struts and they won't take refunds Quote Link to comment Share on other sites More sharing options...
snot35 Posted September 26, 2014 Report Share Posted September 26, 2014 What's a TE16? I don't know if that even exists, are you in the US? If you're sticking to generations, generally anything xE7x will fit in. So, for example, I have TE72 struts in my KE70. They went in using the KE70 strut tops to suit the chassis bolt holes. I've got them bolted to AE86 power steering arms which are actually mated to KE30 lower control arms and tie rods. The TE72 struts are bigger in diameter, I'm using AE86 inserts in mine. AE86 struts can also be used with the appropriate strut tops. Let us know what you're struts are actually from, if there is a TE16 it's very old and there'd be few people here that would be able to confirm it would work I'd image. I'd also be wondering what size brakes you can actually fit to those struts. It would probably be something quite small and unsuitable! Quote Link to comment Share on other sites More sharing options...
parrot Posted September 26, 2014 Report Share Posted September 26, 2014 No such thing as TE16. I suspect Benny Boy has been done in by the old iphone spellchecker. Quote Link to comment Share on other sites More sharing options...
Benny boy Posted October 9, 2014 Author Report Share Posted October 9, 2014 Oh wow thanks sooo much dudes you have helped heaps completely forgot about this topic and yeah I saw a te at the wreckers couldn't remember the model so I put in te1 and 6 came up so I went a ʞ©$ɟ it it'll sort out and yeah went to put "ke70" koni adjustables in a ke70 and shockers were too large for the struts and I wanted to do a brake upgrade anyway Quote Link to comment Share on other sites More sharing options...
