November 2, 201412 yr comment_690171 Trying to replace front brake hoses. Are they a two piece hose or is the metal bit. Just to hold it to the strut bracket. Can't get them undone. Report
November 2, 201412 yr comment_690174 They are a two-piece hose, held in at that bracket. You can hacksaw vertically down into the bracket, bend the metal aside and take out/put in brake lines without taking them in half or remove the strut from the car and leave the caliper there. I'm sure you can buy one-piece braided lines to replace them too. Report
November 9, 201411 yr comment_690437 "PB Blaster" gets em all unstuck...took the two piece hoses to a shop here that makes new brake lines...20 minutes later had single pieces in place. Report
November 10, 201411 yr comment_690452 It's also worth noting that stainless braided lines aren't that much more expensive than rubber lines and all the braided KE70/AE86 lines I've seen are 1 piece. Report
