November 21, 201411 yr comment_690968 Hey soon I'm putting a ke70 4k in my ke10 and ive got my original ke10 4 speed box do i need and other clutchs or anything like that to fit on the 4k or does it just bolt straight on?? Cheers ~ dean Report
November 21, 201411 yr comment_690981 Should bolt straight up. If it was other way round and you had ke70 gearbox then the only difference would be the gear shifter is slightly further back and you would need to cut a new gear shift hole. Report
November 21, 201411 yr comment_690988 Yes the gear box will bolt straight up....but you'll have no drive as the ke10 gearbox has a smaller input shaft. I can't remember if the clutch diameter is smaller or not, don't think so, so you should be able to use either flywheel but with a Ke10 clutch plate. Report
November 22, 201411 yr comment_690998 Yeah you need the ke10 clutch kit as Taz said. Clutch diameter is same but input shaft is much smaller. I also found that one of my early pressure plates would not fit a ke70 flywheel as the studs would not line up Report
