January 23, 201511 yr comment_693382 what jets would be appropriate for a stock 2tc? trying to put a pair of weber's. thanks. Report
January 23, 201511 yr Author comment_693383 and would anyone know where to get linkages. lol mine didnt come with it. Report
January 23, 201511 yr comment_693390 40 DCOE X2 30 CHOKES 4.5 AUX CHOKES 115 MAINS F11 E TUBES 2.00 AIR JETS IDLE 50F9 40 PUMP JET Report
January 23, 201511 yr comment_693392 You will probably have to modify a Redline kit- http://www.redlineauto.com.au/s-272-linkage-components.aspx http://www.redlineweber.com/carb-kits/auto/toyota/ Report
January 23, 201511 yr Author comment_693397 @corollaart would that work witb a 45dcoe152. 45 and 40 the same? @altezza is that for the linkages? http://m.ebay.com/itm/271427388280 would this work? i know i still to so something to make it work on cable. still looking around for more info lol Report
January 23, 201511 yr comment_693402 Yep, that's the one. Not the best design in the world, but it is made to fit a lot of different cars. I made my own linkage setup from scrap around the shed, although I bought the brass djustable arm. It wan't hard & I haven't touched it in the 4years since I did it- The quadrant that rotates on the end of the cable came off some carb lying around, I just had it welded onto a long bolt.. http://www.rollaclub.com/board/topic/42407-the-girls-ke70/ Report
January 24, 201511 yr Author comment_693435 will do that thanks. any idea where to get a manifold asidr brd racing? Report
January 27, 201511 yr Author comment_693548 opened the sidedrafts today and heres what i found in it... f8 emulsion tube 205 air correctors 150 main jets 50/100 idle jet and not sure what the idle tube is, nothing written on it. 36 choke tube. did not take a look at the aux tubes. no accelerator jets. if i run it on this setup it would run very rich right? Report
January 28, 201511 yr comment_693588 The Torana XU-1 ran 36chokes with 150 mains and 190 air, so yours would be leaner if anything, but they are big chokes to run. The bottom end of the rev range might struggle. There is a Ford 122E full race motor listed with twin DCOEs on 36 chokes, they run 135mains and 160airs, so that would stay rich. The Lotus Cortina/Elan ran 36chokes too, with 140 and 160jets. I think the chokes will be far too big for a non-racing motor, even a single DCOE with those parts would run a 2L. Try what you have but expect to go down in choke sizes & jets to something like Corollaarts. Report
January 30, 201511 yr Author comment_693660 well see what happens ill post again when i got it altogether thanks a lot! Report
