January 17, 201610 yr comment_702444 I've got a strange noise coming from the carby whenever I accelerate. Sounds like a ticking/rumble noise. When I turn off the motor, makes a gargling noise. How much would you guys think ball park wise it would cost to fix something like this? I'm not sure if its much help but I took some video footage. Any help would be appreciated. Edited January 17, 201610 yr by deception345 Report
January 17, 201610 yr comment_702451 Sounds like you've blown the exhaust manifold gasket. Pretty straight forward to fix. Report
January 18, 201610 yr Author comment_702458 Is that the gasket between the extractors to the engine? or the gasket between the carby to the extractors? Report
January 18, 201610 yr comment_702459 Same thing - the gasket on a K series engine is shared between inlet and exhaust. They are sometimes available as a two piece item (for cylinders 1 & 2 and 3 & 4) but the one-piece item is more durable. Report
January 18, 201610 yr comment_702466 or the gasket between the carby to the extractors? or is this one the hotbox joint where the inlet bolts onto the exhaust manifold?? Pull it all off the motor. Put a steel ruler along the manifold faces, both inlet and exhaust, to see if they are lined up nicely. If they are not (common) you could try to loosen the hotbox nuts at the bottom of the carb and realign the two manifolds. Buy a one-piece gasket and put it back together. Make sure the bolts and studs have clean holes and threads. Check the bolts in a couple of weeks, they seem to loosen over time. I did it in here- http://www.rollaclub.com/board/topic/27374-one-piece-manifold-gasket-who-makes-them-4k/ Report
